About LM5085 PSpice Model problem
Other Parts Discussed in Thread: LM5085, TINA-TI
I download the LM5085 PSpice Model from TI Website but can't run to LTspice tool and show the message as below.
Would you kindly provide your suggestion for reference?
Thanks your help.
  • Eric,
    It looks like you may be getting a convergence error. Unfortunately, we are unable to support LTSpice. Please consider using TINA-TI. The LM5085 model is already available in TINA-TI so you should have a good working starting point. Also, you can look into the Export of this spice model from WEBENCH to TINA-TI directly. The advantage is that you  not only get the spice model and schematic setup for you, but WEBENCH will provide you with a workign schematic as well. You can also use other features within WEBENCH to fine tune and optimize your design as well.
