Other Parts Discussed in Thread: TINA-TI
Tool/software: TINA-TI or Spice Models
Team,
My customer has the following issue.
I’m having trouble with the LM4041-N-ADJ SPICE model. If I tie V- to GND & bias V+ positive it regulates at the programmed voltage (1.5V). However, if I tie V+ to GND & bias V- negative, it doesn’t regulate. Can you help?
I’ve attached my LTSpice file & symbol.
"lm4041-n-adj" should be an .asy and "adj shunt reg" should be an .asc extension, so please change.
lm4041-n-adj.datadj shunt reg.dat
BTW, what's the best way to post these files?
Aaron
