• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » WEBENCH® Design Center » Simulation and Models Forum » INA333 EMG Instrumentation Amplifier
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
hassan javed warraich
Posted by hassan javed warraich
on Jul 30 2010 13:47 PM
Prodigy120 points
I need some help regarding the simulation model of INA333.
i need to make a PCB design of my circuit which is using INA333. I have made my simulation in TINA-TI simulation software. Now, the thing is that I want a PCB Design for which I will have to use PSpice A/D in OrCAD. There is a Text Document "Instrumentation amplifier SPICE MACROMODEL" available for PSpice at the www.ti.com website. But I have been trying and am not able to run that   *.txt   file in the PSpice A/D software. Can anybody please help me on that. I am not very used to using PSpice/OrCAD =(
Hassan
EMG INA333 Amplifier Instrumentation Simulation PCB Design
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Herman Theodorus - WEBENCH Design Center
    Posted by Herman Theodorus - WEBENCH Design Center
    on Aug 02 2010 11:07 AM
    Intellectual870 points
    Hassan,
    Which version of Pspice/OrCad do you use? Is it 15.7 and above?
    Herman
    INA333
    Report Abuse
    • Reply
  • hassan javed warraich
    on Aug 02 2010 11:12 AM
    Prodigy120 points
    Hi Herman,
    Well yeah its above 15.7 , it is the 16.0 version. I cant really figure out how to make it in OrCAD ., Im even finding it hard to find the footprints/dimensions for the INA333 IC
    Kind regards,
    Hassan.
    Report Abuse
    • Reply
    on Aug 02 2010 11:31 AM
    I am not an expert in PCB usage of OrCad, but if I understand correctly basically you requested
    a test bench of INA333 in OrCad/Pspice so that you can run simulation on it. Am I right?
    Or do you actually need the footprint/dimensions of INA333 so that you can draw layout on OrCad PCB tools?
    If it is the former, we can provide it. If it is the latter, I have to find somebody that knows the answer to this.
    Report Abuse
    • Reply
    on Aug 02 2010 11:36 AM
    Prodigy120 points
    Yeah thats exactly what I requested , the former one. The latter issue I mentioned regarding the footprints/dimensions of INA333, is also some thing I need help with. It would be really kind of you if you are able to help.
    Report Abuse
    • Reply
    on Aug 02 2010 18:42 PM
    I worked on the test benches today and will be posting them most likely tomorrow.
    Regarding the footprint/dimensions..
    We usually put the dimension/footprint for PCB layout purposes on our datasheet.
    For instance if you go into our datasheet of INA333:  http://focus.ti.com/lit/ds/symlink/ina333.pdf
    page 19 to 24.. it discusses about the details of dimension/footprint.
    I am not sure if the answer above meets your need. If you need something more specific,
    can you tell us what specific information you need?
    INA333
    Report Abuse
    • Reply
    on Aug 02 2010 22:05 PM
    Prodigy120 points
    Oh okay I was trying understand it from pages 19 to 24 earlier today. I found it a bit confusing, but I am trying to figure out, since am a bit new to OrCAD 16.0.
    I will work on it the next day as well, so ill tell you if i may need anything more specific on that. And thankyou very much regarding the test benches, hope to receive it from you soon =)
    thanks again Herman!
    Hassan.
    Report Abuse
    • Reply
    on Aug 03 2010 11:20 AM
    Verified Answer
    Verified by Rick Downs - WEBENCH Design Center
    Hassan,
    Attached is the .zip; it includes all the necessary files so that you can just click and run. We will be releasing also this .zip file into our official INA333 product folder
    website just in case you need it in the future.
    You mentioned that you're new to OrCAD 16.0, so I am not quite sure if you happen to know how
    to maneuver around the environment. But just in case you don't use OrCad 16 on regularly basis:
    1. After you extract the .zip into certain folder, double click on the .opj file
    2.To run simulation, simply choose one of the Simulation Profiles such as sim_INA333-ac.
    3. Right click on the sim_INA333-ac and choose "Make Active". Then Right click again and choose "Simulate Selected Profile(s)"
    The schematic obviously located on the .\ina333.dsn. You can expand this by clicking on the "+" sign and again "+" sign on
    sim_INA333 for instance. Then double click on PAGE1 to see the schematic.
    I attached also basic Pspice Tutorial just in case you need it. In this tutorial, it explains the basic of running simulation such as simple RC filter and also
    the basic of exporting a netlist into symbol view so that one can run simulation with it.
    Cheers,
    Herman
    1854.INA333_PSPICE_AIO_02AUG2010.ZIP0724.PSpice Tutorial for Customer.doc
    INA333
    Report Abuse
    • Reply
    on Aug 04 2010 13:10 PM
    Prodigy120 points
    Sorry for the late reply. i just read ur message. I'll follow your instructions and let you know. Thank you so much Herman, you are so kind.
    Cheers, Hassan.
    Report Abuse
    • Reply
    on Aug 05 2010 09:40 AM
    Prodigy120 points
    yeah .. it was all running perfectly fine..
    Now,the "PCB Symbols/Footprints" are not there at INA333 webpage on www.ti.com. Also, I have been analysing the Datasheet of INA333 but its not too clear on the dimensions of the component.
    Report Abuse
    • Reply
  • Rick Downs - WEBENCH Design Center
    Posted by Rick Downs - WEBENCH Design Center
    on Aug 05 2010 11:25 AM
    Expert5510 points
    Are you using the MSOP or SON package? Drawings for both package types are in the product folder. I'll have to check and see if we already have footprints for those packages in OrCAD format. Pretty sure we don't have a schematic symbol for the INA333, but if you have the footprint you can build your own symbol and connect the two - and if we don't have the footprint, you can put one together from the drawings we have on the website.
    Report Abuse
    • Reply
    on Aug 05 2010 12:18 PM
    Prodigy120 points
    I have made a footprint using the dimensions given at page number 20 (of the data sheet of INA333) in OrCAD Layout
    Footprint INA333
    Report Abuse
    • Reply
    on Aug 05 2010 12:24 PM
    Expert5510 points
    Great! That's the drawing for the MSOP package.
    Let us know if there's anything further we can do.
    Report Abuse
    • Reply
    on Aug 05 2010 12:31 PM
    Prodigy120 points
    OOhh yeah it is MSOP =) Thanks bro i'll let you know!
    MSOP
    Report Abuse
    • Reply
    on Aug 09 2010 19:15 PM
    Prodigy120 points
    Can anybody tell me if there is any way I can get an output voltage of 3.3 V at Vout with a "Single Supply" of 3.6V at V+ , and an Input "Vin +" of 10 to 15 mV (coming from an EMG sensor). The input signal can be made to be a sinusoidal signal of 10mV.
    Report Abuse
    • Reply
    on Aug 09 2010 19:17 PM
    Prodigy120 points
    The input signal has to be analog.. please note that.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
