I'm looking to design a inverting SMPS to generate -5V from a 5V USB source. The end application is instrumentation, and therefore I must minimize output ripple.
I'm using TINA TI to simulate my design. I have the following questions:
1) Is the TPS54160 transient model sufficent to model my output ripple at steady state? Or is there some other model that I should use?
2) Can I use this model to see the effect of adding an LC output filter for ripple rejection?
3) If I use the transient model as a power supply to my amplifiers in the TINA TI design, will it accuratley model the effects of supply noise? I'm using the OPA727. My assumption is that power supply effects are probably not modeled on all devices, but I don't know how to check that.
Thank you for your guidance,
Alex
