Other Parts Discussed in Thread: TINA-TI
Tool/software: TINA-TI or Spice Models
I'm having problems with the ADC16S626 Spice Model on TINA-TI because it appears to be different from the pin-out diagram in the datasheet, as far as I know this A/D converter has a serial interface with one digital output since the data is being clocked out bit by bit.
But when I import the Spice Model to TINA-TI the IC has a kind of a parallel interface with 16 outputs showed below,
I have made the conversions by hand and also the results didn't make sense. Also I have imported the reference design and the ADC is connected to a generic 16 bit DAC that generates the correct signal but my objective isn't the same.What I'm trying to do is a capture a data conversion with the 16 clock cycles on the ADC digital output. As last resort I created a new macro in the New Macro Wizard but the import fails because it says the library file is empty; when I open the macro it says the following at the end of the file:
* Encrypted macro. Content can't be viewed. .ENDS |
Any suggestions?
Thanks in advance,
