• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » WEBENCH® Design Center » Power and Lighting Tools Forum » LM5117 WEBENCH design not working at all
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Ignacio Del Castillo Hern��ndez
Posted by Ignacio Del Castillo Hern��ndez
on Mar 06 2012 07:13 AM
Prodigy20 points
I have created a design for the LM5117 using WEBENCH online application.
VinMin: 10V VinMax: 50V Vout: 9V Iout: 3A
I mounted the current circuit and it appear to works fine. Without any load connected, the voltage at the output is 8.99V.
All the components used for the mounting are the recommended by the WEBENCH simulator, exept some resistors, that are the same value, power handling and tolerance, but from another manufacturer.
The problem appears when I connect a load to the output.
In this case, when I connect a load of 5 Ohm at the output(9V/5Ohm=1.8A) and selecting an input voltage approximately below 25V, the buck appear to works, checking that the output voltage drops from 8.99V to 8.65V.
If I increase the input voltage, after exceeding aproximately 25V, the output voltage drops drastically to 1.35V, and the buck stops its regulation. At this point, the input current consumption is near zero.
Once I decrease the input voltage at about 24V, the circuit starts to regulate the voltage again, watching at its output 8.65V.
I have made the test with several loads (10 Ohm, 20 Ohm, etc...) and the behaviour is the same.
Can anyone know wich could be the reason of this behaviour?.
Maybe the main problem could be the compensating network, that is working partially good at the first.
Ignacio
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tommy Jewell - WEBENCH Design Center
    Posted by Tommy Jewell - WEBENCH Design Center
    on Mar 06 2012 12:26 PM
    Intellectual1055 points
    Hi Ignacio,
    Thank you for you interest in TI power solutions, I'm sorry you are having these issues with your design. I'd be glad to take a look and see why this could be happening if you could provide me with more information. If you could give me your WEBENCH design and any schematic and layout files you have it would be helpful. You can either post things to the forum or if you'd like to take this offline you can email me at Tommy.Jewell@ti.com.
    Tommy Jewell
    WEBENCH Apps, TI
    Report Abuse
    • Reply
  • Ignacio Del Castillo Hern��ndez
    on Mar 07 2012 02:47 AM
    Prodigy20 points
    Hi Tommy,
    7506.DCDC_LM5117_components.pdf
    5700.LM5117_sch.pdf
    I attach in this post the WEBENCH design and the schematic. I have also made the calculation manually using the application design example aviable on the datasheet, where there are the expresions for calculate the value of the important components. I have checked that all the values calculated by WEBENCH are right, but I have obtained different components value for the compensation network. I think that is because the WEBENCH selects the fcross at 1/12 the switching frequency, and the design example uses 1/10 of the switching frecuency for a first approximation.
    I have mounted the two compensation networks, obtaining the same behaviour.
    From the WEBENCH calculator:
    Ccom1= 3.3nF
    Rcomp= 27.4K
    Ccomp2= 68pF
    From the manual calcs based on datasheet example:
    Ccom1= 9nF (mounted 10nF because I haven´t got this exact value)
    Rcomp= 33.3K (mounted 33K)
    Ccomp2= 72pF(mounted 68pF)
    Any ideas about what could be happening?...
    Thanks a lot in advance,
    Ignacio
    Report Abuse
    • Reply
    on Mar 07 2012 11:59 AM
    Hi Ignacio,
    I saw this post and also received your email. I will take a look at what's attached and try to get back to you promptly.
    Tommy
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
