• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » WEBENCH® Design Center » Power and Lighting Tools Forum » TPS51315 SIMULATION
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
TPS51315 SIMULATION
TPS51315 SIMULATION
This question is not answered
eli
Posted by eli
on Mar 26 2012 08:57 AM
Genius3610 points
For Vin=5V,Vout=1.05V/6A,looked at the TPS51315.
I used the SwitcherPro to generate a schematics, only thing I have changed was the output capacitor to a capacitor we do have in hand (T495D227K010R0100) which is  a 220uF/ 10V/ 100mOhm.
I have noticed the report (Analysis - Output1 page) states 377mV as Output ripple p-p.
 Is this is the expected output ripple? This is much above the allowed 50mV ripple for the CPU core ...
I have opened the TINA. The built in example in the TINA is also for 1.05V output with a load of 10Amp so I have used it and run it as is.
The ripple over Vout was few hundreds mV.
I have changed this circuit to match exactly the values presented by the SwitcherPro. The results were much worse than before (reducing the Cout ESR value from 100mOhm down to 10mOhm improved this situation but not better than the original result from TI own example.
It is hard for me to exit files, so I can not send you for now the TINA and the SwitcherPro files, but I will appreciate a lot if you can send me a design in SwitcherPro format, or better in the TINA format, that meets my requirements : best if 5V input and   output of : 1.05V / 6Amp / 85c ambient / less than 50mV output
TPS51315
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Heath Gallimore
    Posted by Heath Gallimore
    on Mar 26 2012 09:27 AM
    Intellectual1280 points
    Eli,
    If the 50mV or less output ripple voltage is important to you, you may want to look at another converter.  TPS51315 uses output ripple voltage to directyly control switching so it requires a bit higher ripple voltage than some more standard parts that use opamp feedback to control switching.  I'd recommend the TPS54620 for this application.  I did a design in webench with 4.5V to 5.5V in, 1.05V out @ 6A and chose the TPS54620 in this list of parts.  I took a quick look at the output votlage ripple in the standard design that came out and it was less than 10mV of output voltage ripple with qty 2 22uF ceramic output caps.
    If that solution doesn't work for you there are some other parts like TPS54618, LM20146 and LM20136 that may work for you as well.  You can access webench directly from the main page at www.TI.com
    Report Abuse
    • Reply
  • Britt Brooks - WEBENCH® Design Center
    Posted by Britt Brooks - WEBENCH® Design Center
    on Mar 26 2012 09:54 AM
    Expert7380 points
    Eli,
    The reference design in TINA has a 10mOhm output capacitor ESR and gives approx. 50mV or ripple on the output. Increasing it to 100mOhm would increase the ripple to >450mV of ripple, tripping the over voltage protection circuit and shutting down the part. I do not believe that the 100mOhm capacitor you have chosen can be used with the part if you are seeking a 1.05V out with less than 50mV ripple.
    If you use equation 13 in the datasheet, the ESR required for the output cap is approximately 10mOhm (for Vout=1.05 and Iout=6A).
    Britt
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
