TPS40057 schematic in SwitcherPro has gate capacitor C33. This is not described in datasheet.
How is this value calculated?
According to TPS40055 EVM user's guide, this capacitor value is decided from the capacitance ratio between the gate-source and drain-gate, reducing the voltage which appears on the lower MOSFET gate.
(http://www.ti.com/lit/ug/sluu190/sluu190.pdf)
However, the capacitor value changes depending on external components or input and output condition though same low side FET is used in SwitcherPro. Thus our customer requires the calculation method.
5751.TPS40057 DesignReport.pdf
Kohei Sasaki
