How to assign the load as source in webench online tool ?
Hi ,
  Please guide me to use the one output voltage as the input voltage of second level regulation in webench tool.
  • Are you trying to design a multi-stage power supply or simply trying to design a power supply from a know input voltage? If you are trying to generate multiple output voltages from a single input, the WEBENCH® Power Architect is the tool you should use. If you are simply trying to generate a new output voltage from an exsiting input voltage, you should use the WEBENCH® Power Designer.
    Can you give us a little more detail about what you are trying to achieve? If you can share the input voltage, output voltage(s) and currents, we may be able to help further.
    Britt
