Hello I need help getting a successful simulation. I am receiving this failure message:
Your simulation failed due to a netlist error. If you recently changed a component in the BOM or changed a simulation related parameter, try changing it back to its previous value. If the problem persists, it may be due to an internal problem in our system. The problem has been logged and the development team has been notified. If you have any questions, please submit a feedback online at webench.ti.com/.../.
Error File Contents:
Simulation: FAIL
* ERROR * cir.pspice[293:16-293:18] - Syntax error. Unexpected token: integer number (PARSER-2)
* ERROR * Parser error... bailing out. (PARSER-1001)
**************** ERROR/WARNING COUNT ****************
Type: PARSER #errors: 2 #warnings: 0
--TOTAL-- #errors: 2 #warnings: 0
FAILED SIMULATION
Status = Fail
I have made sure that all components have the values of the parameter range recommended. I have no netlist errors and no warnings. I figured it must be something wrong with my schematic. Below is an image of my schematic. Can someone please help. Thank you.
