I'm testing the new Power Designer Webench tool and have found that all the designs have wrong time stamp. All the new one (that I've been working on last few days) as well as some older ones (weeks and months back) show wrong date. The shown month is January 2018 (instead of July), while the date seems to be correct. For example, the design that I've started today has assigned date "13 January 2018", where the number 13 is correct but the month should be rather July.
Also the simulation results are not consistent and when I ran the same design next day I got different results (Phase margin in this specific case). I do not want to go into details as it would be for separate thread. It does not convince me I can rely on the simulation results and calculations. The Phase margin calculated in "CUSTOMIZE" section is significantly different (sometimes!) than the same value shown in SIMULATE section.
Is the new version of Power Designer preliminary or test build? Or is it still under development? I haven't seen such notification anywhere.
Thank you.
Josef Rýpar
