• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » WEBENCH® Design Center » Signal Chain/Signal Path Tools Forum » FilterPro 2.0 vs 3.1 show different component values
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Scott George
Posted by Scott George
on May 10 2011 10:37 AM
Prodigy10 points
Made design at home using FP2 and FP3 at work to find very different component values for filter at output of RTD temp sensor.  Filter is 1 Hz, 2 pole LPF, Gain = 1 (0 dB), MFB Single end, Butterworth, using E96 resistors/ E12 caps.  FP3 Gain plot shows -30 dB in pass band though header shows G = 1.   Can not edit FP3 values to FP2 values.  Discrepancy between FP2 and FP3 seem to start below 10 Hz.  Which is correct?
FilterPro 3 Filterpro
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Faisal Ali
    Posted by Faisal Ali
    on May 10 2011 11:12 AM
    Verified Answer
    Verified by Rick Downs - WEBENCH Design Center
    Prodigy270 points
    Hi Scott,
    Thank you for reporting this issue. This is a resolution problem in FP3. Since Lowpass filters at such low cutoff frequencies are impractical, the support in the FP3 plots is limited and any frequencies under 10 Hz will most likely demonstrate the same behavior. The real issue is that there are not a whole lot of points available to be plotted at such low frequencies and, therefore, it is hard to see the actual cutoff at 1 Hz. If you use a simulation software e.g. TINA-TI and build the circuit that FP3 has generated, you will see that the resulting circuit is accutate and waveforms display the cutoff accurately.
    This issue is already known and will be addressed in the upcoming releases.
    Thank you,
    Faisal Ali
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
