• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » WEBENCH® Design Center » Signal Chain/Signal Path Tools Forum » Designing band pass filter using STLM358
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Danny Hardin
Posted by Danny Hardin
on Aug 09 2011 13:40 PM
Prodigy10 points
I've used the Filter Pro and I'm having problems with cross over distortion using the values recommended by Filter Pro.
I'm desigining a Sallen Key Butterworth Bandpass
Gain: 10V/V
Corner frequency Attenuation: 16.998 dB
Stop Band Bandwidth: 24 kHz
2 Stages
Allowable passband ripple: 1dB
Stopband Attenuation:-21 dB
Center frequency: 17.5 kHz
Passband Bandwidth: 7kHz
I'm powering the LM358 using +/-12v supply.
Center frequency should be 17.5kHz but measures ~15kHz. I believe this is due to the cross over distortion interfering with bandpass?
Any help would be appreciated.
Danny
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Rick Downs - WEBENCH Design Center
    Posted by Rick Downs - WEBENCH Design Center
    on Aug 09 2011 14:58 PM
    Verified Answer
    Verified by Rick Downs - WEBENCH Design Center
    Expert5510 points
    Danny,
    Cross over distortion would cause distortion, but shouldn't affect center frequency. What's at work here is inadequate gain bandwidth of the op amp.
    I put your parameters into FilterPro and created a design - the design report is attached: 8182.bp.pdf
    Note that the op amps require 17-22MHz of GBW product. An LM358 only has about 1MHz GBW. This will cause the center frequency to shift.
    I built the design in TINA-TI v9, the circuit is attached: 6786.Sallen-Key 4th Order Butterworth BPF.tsc
    Running this using an LM358 versus an OPA228 (which has about 30MHz GBW) results in this:
    The center frequency using the LM358 is indeed around 15.5kHz, while the OPA228-based design places it right at 17.5kHz, as expected.
    Make sure to look at the GBW requirement of op amps when designing active filters! As you can see here, it really does matter!
    Sallen-Key gain bandwidth Filterpro TINA-TI
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
