Hi, Sanjeev,
I have load first set 24--1bit image to DMD with no problems. I can switch between them in less than a few millisecond. Since the specification told, it can load 48--1bit image in C350. My question is how to load 25th to 48th image to C350 ram buffer and switch it in millisecond way.
My application need to use 30---1bit images, i need to display them in a few millisecond switch time.
I have read through the Programming document and try all the menu command in LightCraft GUI, but i only can find use the 24bit image to add plane sequence.
Could you help me on this issue? or I have miss understanding to use 48bit-1bit plane images. Thanks in advance!
Best Regards!
Eric
