Part Number: DLP3000
Hi, I need some help. I am trying to run <LCr3000_3D_Scanner_Application_v2/DLP_LightCrafter_3D_Scan_Application.exe>, but I have encountered some problems.
I use the document <TIDA-00361: Portable Point Cloud Generation for 3D Scanning Using DLP® Technology User's Guide, TIDU985A>. I am using Microsoft's LifeCam webcam. I was having problems with camera calibration in the order in the documentation.
Follow the prompts to enter command 4 to perform camera calibration. The projector does not project white light, but the projected green light.
Below is config_projector.txt
When I modify the value of LCR3000_PARAMETERS_PATTERN_LED_SELECT, modify it to BLUE, RED, and the projector will also project the corresponding color of light. However, how can I cast white light in an image document?
Thank you in advance.
Best.
Kang.
