Hi, I'm hoping someone can help,
I'm trying to locate the DMD chip that was used in the NIKKO R2D2 DVD Projector as I need to replace it.
Cheers Leonard
Cheers Leonard
Hi Leonard,
Thank you very much for your post!
From doing some quick research online, I found the chip used in this product is the 0.55" XGA (1024 x 768) DMD. The closest product that we have available to mass market customers is the DLP550JE.
However, the most used in your system is likely in a different package, meaning this product wouldn't be compatible with your R2D2 projector. Please contact the manufacturer of the product to have them order you an exact replacement!
Brandon
Thanks, Brandon,
unfortunately, the company went under some time ago, as only 1000 had been made owners are not that forthcoming with information.
Cheers Leonard
Are you able to safely remove and post a picture of the back of the DMD ?
Thanks for the post, Carey I will attempt to remove it later today.
Cheers Leonard
Hi Carey,
I'm having difficulty accessing the DMD, still trying to figure out how to access and separate from other components. this is why it's difficult https://www.youtube.com/watch?v=fpVQ_BXZOHw
I'll keep you posted.
Cheers Leonard
