Hello User,
I'm a bit confused about the issue you are reporting. Can you elaborate in more detail about the failure case you are encountering?
It sounds like your system is failing to produce any output after the first trigger. Is this correct?
Philippe Dollo
Hi Jia,
Thanks for detailed explanation, Could you kindly try with the latest LCR4500 GUI v4.0.3 and DLPC350 FW v4.1.0 and see if the issue is still reproducible?
Thanks & Regards,
Hirak.
Hi Hirak,
I only see links to LCR4500 GUI v4.0.0 on the site. Is there another link we should be looking for?
Hi Brian,
Kindly also download the DLPC350 FW v4.1.0 from this page, flash it and use it with LCR4500 GUI v4.0.0.
Thanks & Regards,
Hirak.
