Thanks for your time. I want to ask do you have any recommended mDDR part for DLPC300. The compatible 256Mbit part in the datasheet are all EOL. How about ISSI IS43LR16160H-6BLI?Thanks in advance.
Best regards
Best regards
Hello Kevin,
We have very limited support for this controller because accompanying DMD has been EOL.
The best option would be refer to details of memory interface requirement listed in DLP2607 controller datasheet - section 6.15 (page 19).
https://www.ti.com/lit/ds/symlink/dlpc2607.pdf?ts=1591309725340
These two controllers have similar memory interface requirement.
regards,
Vivek
Hi Vivek,
Thanks for your reply. I understand this situation.
My customer is using IS43LR16160H-6BLI, however it didn't pass their test. But the recommended mDDR did. They also compare the two mDDR spec it seems fine. That's why I ask if we can help to check the spec.
Kevin
