Hi
I am having a problem that when i plug in my DMD via the display port it turns off all my other monitors, regardles of what graphics card they are plugged in to.
Hi
Max,
Is this the same machine that you have tried different video cards in or different systems. This sounds like a windows issue.
Here is what I would try. Get hold of a DisplayPort (DP) monitor and plug it in. Does it also result in turning off the other monitor(s)?
If it does, then using that monitor configure to Windows to display on both and set the another monitor to be the primary display. Then unplug the DP monitor and plug the DLP6500 LightCrafter EVM in with DP and see if it works then.
Fizix.
