Hello.
I’m trying to configure my LightCrafter 6500 using the I2C port. I've based my I2C command sequence on Table 5.2 (Pre-stored Pattern Mode Example) in the manual of “DLPC900 Programmer’s Guide” .
It seems that everything is going well and finally i can get the images i want. But then I saw this notice in the chapter 2.4.4.3.4.(Pattern Display LUT Definition)
The words in bold show that I should send the command of LUT Configuration (0xF5) first and then send the command of LUT Definition (0xF8). So what does this sentence mean and which sequence of configuration should i respect?
Thank you very much.
