Other Parts Discussed in Thread: DLPC350
Hello TI engineer,
I am currently working with LC 4500 and I am facing 2 problems:
1. Building solution in MFC.
Basically I am following the example as in this post: e2e.ti.com/.../365607
I tried with Console version, and it works fine, but when I make project with MFC, and build, it report a lot of errors:
- err LNK2001: _imp_setupDigetClassDevsA .............. usb.obj or hid.obj
- ..... 5 more in the same category
=> so my question here is: how can I make it work in MFC? do you have any simple MFC sample that can share?
2. How can I project a single pattern in sequence mode?
- I worked with Lightcafter previous version and it was very convenient that the next pattern can be fired by command: LCR_CMD_AdvancePatternSeq();
=> Is there any similar function for LC4500?
What I want is I project a pattern, then wait until camera grabbing procedure finish, project the next pattern,... and so on.
I hope you can share some information on these issues.
Thank you very much and have a nice day.
Best regards
Bui Quang Lam.
