Other Parts Discussed in Thread: DLPC350
Hello everyone, I just bought the PRO4500 light engine form Wintech Digital using the DLPC350 dmd chip from TI.
First, I recently would like mount the projector on the microscope in lab. I am wondering if there is any recommended suspending system to hold the projector in vertical direction with which we can have the pattern on the horizontal plane. Is there any commercialized equipment that would achieve this?
Second, I would like to ask for your kindly advice to attach the projector to the microscope. I need to observe the manipulated object and expose it in the same time. But I have no direction which field to start researching from building up the system to re-focusing problems. Would you also please hint me a little bit about which optical tube or Microscope to use in this kind of application?
Thank you!
