Hi
Do you know what the transmittance is for wavelengths below 600 nm? I'm considering using a white light source and was wondering if the NIR DMD could reflect white light and IR.
According to the PDF, it drops off to 80% at 600 nm so it will be worse into the 500 nm range. How much worse is it? Will the device not reflect anything?
http://www.ti.com/lit/an/dlpa031c/dlpa031c.pdf
-Vincent
