• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCommander Development Platform » DMD stability concern operating under high frequency
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
This question has suggested answer(s)
wei hao chang
Posted by wei hao chang
on Jan 30 2012 17:25 PM
Prodigy100 points
Dear Texas Instruments,
I have the following concern when I was conducting my experiments using the DLP light commander.
When I was projecting fringe images using the light commander, I have the setting as 716hz, projecting image using 1024 x 768, 8 bits.I projected a progressive fringe patterns, using the so-called sinusoidal technique; having the darkest part (as black) at the centre and slowly fading away toward both sides (white). Though, when I viewed it with a video camera with resolution of 640x 480, frame rate of 200fps, the projected image seems to be unstable.
Firstly, it shows discontinuity between each projected pixel. Secondly, the centre of the image doesn't seem to be projecting stable dark image; it fluctuates between black and grey. Thirdly, the flickering also occur on suppose-to-be white zones; flickering black lines sometimes occur. Furthermore, instead of being perfectly black right at the centre line, an area around the centre line tend to be in the same colour as the centre line.
I am wondering if this is due to DMD instability when operating under high frequency(716Hz).
Wayne
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Pascal DLP
    Posted by Pascal DLP
    on Jan 31 2012 14:09 PM
    Suggested Answer
    Expert7510 points
    Wayne,
    It is definitely not a "stability" issue with the DMD. I believe that what you are seeing is the result of "beat" frequencies between the camera shutter rate and the DMD subframe rates.
    You mention that you are using 8 bit images on the LightCommander. This means that each image is being displayed as a series of 8 subframes of varying duration (to obtain the gray scale). If the camera is running at 200 fps, it will not be synchronized with the total frame rate of 716 Hz, and certainly not with the varying length subframes of each displayed image.
    So, what you are seeing is the fact that the camera is seeing a different part of the image sequence every frame. This would lead to the appearance which you are describing.
    Pascal
    Pascal
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
