• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCommander Development Platform » Pixel pulsing
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
Pixel pulsing
Pixel pulsing
This question is not answered
Anthony Zorzos
Posted by Anthony Zorzos
on Feb 22 2012 13:35 PM
Prodigy100 points
I would like to divide the DMD chip into various bundles of pixels, and pulse those pixels so that they are "on" for a short amount of time (downwards of a 5ms pulse).  Can you recommend a software/method to do this?  I would potentially like to pulse the different pixel bundles for different durations and rates.
Anthony
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Fizix
    Posted by Fizix
    on Feb 22 2012 15:41 PM
    Expert5140 points
    Hello Anthony,
    This cannot be done on the LightCommander Platform.  The LightCommander only loads full frames.
    However the LightCommander can display full binary frames at 5,000 frames per second.  That is a display time of about 200 us.
    Are your patterns deterministic or calculated "on the fly"?
    If you specifically need to control subsets of pixels, this kind of operation can be done with the Discovery 4100 platform.  For purchasing information please see this link:
    http://www.ti.com/analog/docs/memsmidlevel.tsp?sectionId=622&tabId=2447
    This system is much more powerful in terms of speed and lower level control, but does require custom APPS_FPGA programming.  There are sample APPS_FPGA VHDL projects available as a starting point when you purchase a D4100 kit.
    Fizix
    Report Abuse
    • Reply
  • Anthony Zorzos
    on Feb 22 2012 16:12 PM
    Prodigy100 points
    Hi Fizix,
    My patterns are definitively known, and NOT calculated "on the fly."  By displaying "binary" frames, does that imply I can only alternate between two full-frames?  Or can I display a series of different "full-frames"?  If that latter is the case, then I suppose it would be possible to feed the system a series of different frames which would, in effect, "pulse" the correct bundles at the correct time.  Does that sound right?  Thanks again Fizix,
    Anthony
    Report Abuse
    • Reply
  • Sanjeev
    Posted by Sanjeev
    on Feb 22 2012 23:56 PM
    Expert5535 points
    Hi Anthony,
    Binary frame is the one where each pixel in the frame is represented as either '1' or '0'. So 'every' pixel in the frame will be either 'black' or 'white'. LightCommander(TM) can do a) binary b) 8bit grayscale. In 8bit gray scale each pixel can have a 8bit greyscale value 0x00 to 0xFF.
    As my colleague  Fizix mentioned the the lowest level of control in LightCommander(TM) is upto 'binary frame'. You can load and refresh binary frame upto 5KHz.
    Now, going back to your earlier question, "I would potentially like to pulse the different pixel bundles for different durations and rates" my point is that you 'will' be able to use LightCommander(TM) if the your requirement on the number of pixel bundle and duration of each works out to be simple.
    I have provided a example in below picture, let me know if this could help meeting your requirement.
    Sanjeev
    Report Abuse
    • Reply
  • Anthony Zorzos
    on Feb 23 2012 05:35 AM
    Prodigy100 points
    Hi Sanjeev,
    Yes, that makes perfect sense.  What software would you recommend for feeding those binary-frames into the light commander (in the method you outlined above)?  Thanks,
    Anthony
    Report Abuse
    • Reply
  • Sanjeev
    Posted by Sanjeev
    on Feb 23 2012 05:45 AM
    Expert5535 points
    Hi Anthony,
    Once you purchase the kit you will have to register the kit on LogicPD website and then you will be able to download the DLP LightCommander(TM) control software. Using this you can create projects and download the patterns and set the frame rate etc...
    http://www.logicpd.com/products/system-on-modules/dlp-lightcommander-development-kit/
    Refer to kit user manual this will explain in detail on project creation and programming patterns.
    Let me know if you have any further questions.
    Sanjeev
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
