• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCommander Development Platform » Increasing frame rate of DLP using LED dimming
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
This question is not answered
Christopher Tate
Posted by Christopher Tate
on May 04 2012 06:38 AM
Prodigy55 points
Can someone explain (with example number calculations) the concept of modulating an LED light source to speed up the frame rate of the DLP.
Specifically using the .7 XGA chip and its inherent limitations today. Any help is appreciated. If there are TI docs on this already or papers in the community
that would help also.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Justin Lemon
    Posted by Justin Lemon
    on May 04 2012 11:21 AM
    Intellectual285 points
    Hi Christopher,
    I hope all is well today.  Thank you for your participation on the E2E site.  Below is some information and answers regarding your inquiry above.  I hope this helps out.
    When projecting simple binary images (typical of Discovery setups) there is no way to increase frame rate by modulating the light source.  The max frame rate for binary images is dictated by how fast the hardware can load the DMD array.  For producing grayscale images with a DMD, a series of time weighted binary images is displayed in rapid succession.  The minimum realizable duration of DMD mirror switching is what dictates the max possible frame rate, as follows…
     Assume that the fastest possible off-on-off mirror transition interval is 20 usec (approximately correct).  To create an 8-bit grayscale image, you need to project at minimum a series of 8 binary images with the following durations:
    LSB=20usec, LSB+1=40usec, LSB+2=80usec, etc... etc… LSB+7=MSB=2560usec
     Add them all up and you get a frame time of 5100usec (which is not coincidentally equal to 255*20usec).
    To render a complete 8-bit grayscale image any faster, you need a shorter LSB time.  You can create an “effectively” shorter LSB time by dimming the light source during the LSB mirror interval.  Cut the source intensity in half during the LSB and you have an “effective” LSB of 10usec.  Alternately, the LED can be strobed with a pulse duration of just 10usec.  In either case, the DMD mirror must still remain in the on-state for 20usec, because it cannot switch any faster, but the integrated brightness during the LSB interval will be cut in half.  Now the realizable frame time is something like 255*10=2550usec.
    Actually, the realizable frame rate is somewhat lower than would be suggested by the preceding simplified calculation because of DMD loading constraints, but this is approximately correct and illustrates the major limiting factor.
     Please let me know if you need clarification on any of this or if you have any other questions:
    Justin Lemon
    Digital Light Innovations
    512-615-4630
    jlemon@dlinnovations.com
    Report Abuse
    • Reply
  • Christopher Tate
    on May 08 2012 07:22 AM
    Prodigy55 points
    Can you tell me what the limitations of the LightCommander are.
    What is the highest frequency/shortest duration it can modulate/pulse the LED?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
