We are trying to control image change in the DLP via external trigger.
We are using EXP_CON_SYNC_IN0 for this and connected everything properly.
The trigger works but only problem is it looks as if the hardware skips some triggers which resulting in a bad sequence and not as defined in the LUT.
I have tested the input trigger to the J505 connector with a scope and it looks good.
A typical input trigger is 4 5000 [us] pulses wide separated by a 100[us] .
Id appreciate your help.
