• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCrafter Development Platform » near UV use of DLP
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
near UV use of DLP
near UV use of DLP
This question is not answered
Domenico
Posted by Domenico
on Mar 29 2012 10:02 AM
Prodigy20 points
Good morning
I'm planning to change lightcrafter optics and use a 405nm 500mW source; we know this is outside TI specification ( >420nm ), but some test we did with pico projector worked fine in our application. What kind of problem should arise, perhaps shorter lifetime? Or will be available a "uv-graded" DLP sized like DLP3000?
thank you
Domenico
UV
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Pascal DLP
    Posted by Pascal DLP
    on Mar 29 2012 09:06 AM
    Expert7515 points
    Hello Domenico,
    Welcome to the TI DLP&MEMS e2e forum.
    You are correct - the usage you propose is outside the specifications for the DLP3000 DMD device. The result will be shortened operational lifetime of the DMD. Use of the DLP3000 under these conditions is at your own risk. However, if it works for you, that is great.
    There are no plans at this time for a UV rated DLP3000.
    We are interested in your application and your experience with this project.
    Pascal
    Pascal
    UV DLP3000
    Report Abuse
    • Reply
  • Domenico
    Posted by Domenico
    on Mar 29 2012 09:28 AM
    Prodigy20 points
    hello Pascal
    Thank you for your reply. My question now is if you have some extimation of lifetime in this working condition...  Using DLP Discovery 4100 XGA, the closest  uv rated device, may be too expensive for our application.
    best regards
    Domenico
    Report Abuse
    • Reply
  • Justin Lemon
    Posted by Justin Lemon
    on Mar 29 2012 09:36 AM
    Intellectual285 points
    Hi Domenico,
    I hope all is well.  My name is Justin Lemon and I am a Technical Support Consultant at Digital Light Innovations.  I just came across your post so I wanted to contact you to see if I could help clarify this for you.  I just consulted with one of our Engineers and they said if you use a light source that gives off a higher power density than the TI specifications (in your case you are only going with a light source that is outside the TI specification by about 80 mW), it will degrade the overall life of the DMD.  To elaborate, it's not like the DMD will just completely fail and stop working all of a sudden.   Instead, you will start getting stuck pixels in the middle and outsides of the DMD.  Those mirrors will start showing stuck black and white pixels, so when you start seeing that, you will know the DMD is starting to degrade.
    But if you absolutely need to run a higher power density than recommended by TI, once the DMD starts degrading, you can always purchase another DMD by itself and just replace it.  I know you would be spending more money, but if you need to do so to continue your project, experiment, etc. that is what you are looking at.  In regards to the "UV graded" DLP sized chip, let me do some more research and I will get back with you as soon as possible.
    In the meantime, if you have any questions or need anything, please do not hesitate to contact me directly.  I included my contact information at the bottom.  I will get back with you shortly once I have some more answers for you.
    Justin Lemon
    jlemon@DLinnovations.com
    512-615-4630 office
    512-615-4635 fax
    www.DLinnovations.com
    DIGITAL LIGHT innovations
    Report Abuse
    • Reply
  • Justin Lemon
    Hi Domenico,
    I just saw that Pascal kindly answered your question regarding the D3000 UV DMD.  You are correct about the DLP Discovery 4100 XGA Kit having the closest uv rating you can find.  You mention that it is too expensive for your application so I wanted to see what kind of budget you're working with and what you consider "too expensive."  I ask because we also sell the Discovery Kits and we can always send you a quote so you can get a better idea of the cost as well as what all comes with the D4100 XGA UV Kit.  I can also send over a very informative brochure on the D4100.  It lists your various kit options, as well as a detailed explanation of the included items and advantages the D4100 will give you that will not be able to find with any other DLP-based technology or kit.
    If you could kindly send over your email address, I can send over the D4100 Brochure as well as a Wavelength Efficiency Chart that shows the Transmission of each wavelength at various ranges.  I believe you will find both documents very helpful to you, especially in your case.  I look forward to hearing back from you.
    Justin Lemon
    Tech Support Consultant
    jlemon@dlinnovations.com
    512-615-4630 x 4630
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
