• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCrafter Development Platform » Flex Cable on Lightcrafter
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
This question is not answered
Ryan Nobes
Posted by Ryan Nobes
on Apr 09 2012 11:09 AM
Prodigy30 points
I need to have a flex cable between the DMD and the Lightcrafter controller Board. I was planning on removing the middle board with the Aces connector on it and plugging into the Panasonic connector on the back of the DMD with support. What is the best way to do this?
DMD
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Divya
    Posted by Divya
    on Apr 03 2012 17:42 PM
    Expert3680 points
    Hi Ryan,
    I am still researching and will answer you in couple of days. Thanks for your patience.
    Divya
    www.ti.com/mems
    Report Abuse
    • Reply
  • Divya
    Posted by Divya
    on Apr 05 2012 16:12 PM
    Expert3680 points
    Hi Ryan,
    Unfortunately, a commercial cable does not exist for this particular chipset. You will have to develop a custom cable and a PCB connector to match your specific requirements. I will be glad to help you with the design layout. Can you give me some background on your applicatiion, so I can help you better.
    Divya
    www.ti.com/mems
    Report Abuse
    • Reply
  • Ryan Nobes
    on Apr 09 2012 06:02 AM
    Prodigy30 points
    Hi Divya,
    What we are trying to do is add a flex cable about 2 or 3 cm long going from the back of the DMD to the lightcrafter kit. I have the document that provies the signal matching requirements. I'm just wondering what is the best way to layout the flex?
    Ryan
    Report Abuse
    • Reply
  • PedroGelabert
    Posted by PedroGelabert
    on Apr 09 2012 09:28 AM
    Intellectual1980 points
    Ryan,
    Here are some recommendations for the DMD flex cable:
    DMD_VCC traces at leas 0.05" wide. Combined they carry up to 50mA current (average). Up to 2.25A current spikes from decoupling capacitors. Ideally DMD_VCC can be a power plane.
    VREF, VOFS, VRST, VBIAS traces at least 0.015" wide. They carry up to 2mA currents (average). Up to 600mA current spikes from decoupling capacitors. Make these traces wider if possible.
    Signal traces at least 0.003" wide and have a 50 ohms +/- 10% matched impedance. Make these traces wider if possible. Minimum of 2X distance between the signal traces. Ideally, 3X distance between them, wherever possible, compared to signal trace width. Place ground traces between DMD_Dx signal traces wherever possible.
    Use top layer for the DMD_VSS ground plane at the connector.
    0.1uF decoupling capacitors are placed on the bottom layer as close as possible to their respective connector pins (DMD_VCC, VREF, VBIAS, VOFS, VRST). At least two 0.1uF decoupling capacitors for DMD_VCC. Add extra capacitor footprints between other DMD_VCC pins and DMD_VSS if space permits. Capacitors with smallest footprints are chosen in order to fit the DMD flex and for lowest ESL.
      Pedro
    Report Abuse
    • Reply
  • Ryan Nobes
    Prodigy30 points
    Thanks for the advice Pedro I will give this a try.
    Ryan
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
