• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCrafter Development Platform » LightCrafter Issue: Repeated frames at high frame rates
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
This question is answered
Stephen A Kupiec
Posted by Stephen A Kupiec
on May 08 2012 20:04 PM
Prodigy80 points
I have encountered an issue related to repeated frames in long (>16) frame binary pattern sequences at high (>2000 fps) framerates.
I have generated my own python class to drive the Light Crafter allowing for access to all documented commands. This includes full decoding of response packets.
At present I am using a 68 frame long sequence operating at 4000 fps for a tracking application using structured light. During initial testing I encountered a double frame occurring at the 17th time slot. Having thoroughly checked my detector electronics and python driver software I was able to eliminate them as a source of error. The problem is consistently repeatable.
When a sequence of 68 binary patterns are loaded, and run in auto trigger mode, four of the frames (the 17th, 34th, 51st and 68th all multiples of 17) repeat in two sequential time slots. As a result the actual duration of the sequence is 72 slots. Identical results occur at 3000 and 3800 fps but vanish at 2000 fps. Repeating the process in command trigger mode indicates that all patterns have been loaded correctly and are in the correct sequence. For example a grid of rectangles with one non overlapping rectangle per pattern results in a visible pattern with the doubled frames twice as bright as the others. Several other pattern lengths have been attempted with the duplications occurring at different multiples. The result is repeatable across multiple Light Crafter units as well.  While this is not a fatal problem for my present application it is of considerable importance to anybody dealing with timed sequences in the Light Crafter.
This may well be associated with skipped frames that occur under external triggering.
Are updates to the firmware forthcoming?
LightCrafter bug high framerate repeated frames
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sureshkumar Manimuthu
    Posted by Sureshkumar Manimuthu
    on May 08 2012 23:46 PM
    Verified Answer
    Verified by Stephen A Kupiec
    Prodigy350 points
    Hello Stephen,
    It appears that you are using the exposure time of 0 (this is only allowed for <= 24 binary patterns).
    Please set the exposure time correctly and see if the problem goes away.
    Also note that for > 24 binary patterns, the trigger period cannot exceed (exposure+load-time+buffer-swap-time)
    where
    load-time = 235us
    buffer-swap-time = 135us
    Suresh
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
