Hi! I have problems to read patterns from the LightCrafter.
I send a read command 0x0401 and get 65535bytes as a response.
Then I get packet type 0x00 (busy) and I'm not able to get the rest of the image (larger than 65k).
I tried to send read command only once and read many times, I also tried to send read command before to look for responses and in this case I also tried to set flag (buffer[3]) to all possible values (0x00, 0x01, 0x02, 0x03).
Which is the correct way to handle this command?
Thanks a lot for any hint you could give to me.
