Hello TI team,
When I using camera capture function in the software controller, it prompts "COMMAND FAILED". The other function are in good condition. Thanks!
Zou Bojing
Hello TI team,
Zou Bojing
Hello Zou,
Did you install camera at the J2 on the system board? If so which sensor is populated on the board?
The supported models discussed in this thread http://e2e.ti.com/support/dlp__mems_micro-electro-mechanical_systems/f/850/t/321948.aspx
Sanjeev
