Hello everyone
We started this week to work with the CMD our laboratory we try to combine the DND computer and send images by LABVIEW.
Is there an explanation of how to do it?
Thank you
Yanay
Hello everyone
Thank you
Yanay
Hi Yanay,
Unfortunately we do not have code developed in Labview. But, some developers use Labview for the LightCrafter and shared their code in this TI E2E Forum. Hopefully they might be able to help you. I suggest reading this post.
A214529
First, the LightCrafter when connected to PC via USB interface automatically detected as TCP network device. The PC where you are running the Labview must be able to ping to the lightcrafter default ip address 192.168.1.100; if it is not able to detected, you can search on the net for RNDIS driver and install the same on the PC. Once you are able to ping to the ip address proceed to next step.
Secondly, for Labview tool it is like writing to any other TCP port, so follow the instructions from NI for writing/reading from a port http://www.ni.com/white-paper/2710/en/
Third, for writing and reading, you must frame the data into the write and read buffers, the command buffer details can be found here http://www.ti.com/lit/ug/dlpu007d/dlpu007d.pdf
Sanjeev
