A) can the system be powered using lithium ion battery rather than a wall charger? Can it be powered by the computer?
Hi Dylan,
Many of your questions depend on the system design, but I will assume you are referring to the LightCrafter 4500 as it is. Please correct me if this assumption is incorrect.
Hope this helps!
Blair
Thank you your answer was very helpful and you assumption was correct.
For a wireless connection would I be able to use a BeagleBoard to relay an image to the LightCrafter
Hi Dylan,
Possibly, but I'm not very familiar with the BeagleBoard. You can definitely stream an image to the LightCrafter 4500 and control it from the BeagleBoard, but I wouldn't be able to help you with the BeagleBoard itself.
There are a lot of resources for the BeagleBoard on their website (http://beagleboard.org/) and they also have a forum where you could get help using the BeagleBoard.
Blair
I just had one more question. What type of input can the demo device accept and display without significant amount of preprocessing? For example, can I project a slide from a PowerPoint presentation on my laptop directly.
Hi Dylan,
Yes you can. In the LightCrafter 4500 Control Software GUI you can set the device to "Video Mode" and plug your computer video output into the mini-HDMI connector of the EVM. Also, by default the device starts in video mode unless you've modified its default settings.
Blair
