• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » New DLP Applications & Technology Forum » diffraction pattern on a confocal microscopy application
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
This question is not answered
michele pascolini
Posted by michele pascolini
on Mar 14 2012 09:13 AM
Prodigy25 points
I am studying the possibility to use the dmd for a confocal microscope. A big issue for me at the moment is the diffraction pattern I am obtaining in the detector, superimposed to the object image. Are there solutions to overcome this problem?
DMD diffraction pattern
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Pascal DLP
    Posted by Pascal DLP
    on Mar 14 2012 10:36 AM
    Expert7510 points
    Hi Michele,
    Welcome to the TI DLP&MEMS E2E forum.
    Could you give more detail on what your setup is and what you are seeing? Diffraction is a physical property of the geometrically repetitive structures of the DMD and the wave properties of light. However, there may be architectural considerations which can minimize the effects. I can't offer anything specific until I know your arrangement in more detail.
    Pascal
    Pascal
    DMD diffraction Confocal Microscopy
    Report Abuse
    • Reply
  • michele pascolini
    on Mar 15 2012 03:23 AM
    Prodigy25 points
    Dear Pascal,
    thank you for your reply.
    The system we are evaluating at the moment uses an LED source (and not a laser) without polarization (I guess it would be needed, but we would not want to move towards a laser source, anyway).
    The incident angle is 24 degrees with respect to the dmd "0 state", in order to use the "on" state to send light parallel to the dmd axis. At the moment the illumination path creates a converging beam to the dmd (probably a parallel one would be better, I guess). Then there is a tube lens infinite conjugate and the microscope objective.
    A displaced mirror actually acts as spatial beam splitter and reflects the light in the imaging path. I am experiencing - at the moment - that the sample creates a pattern after the imaging lenses  when is located at the confocal distance. I am introducing a mask in the imaging path to spatially remove all the light but the one due to the sample. However, of course, even the backscattered /refracted light coming from the dmd itself is partially allowed to reach the ccd.
    If this problem does not affect the image when I need a very low level of light in the sample, it becomes very critical when I need to go inside the sample itself (I am dealing with human cells). My samples, in fact, have very low level of diffusion, so they are a bit a nightmare ...
    I am pretty sure the undesired light is coming from the dmd because I can detect it even when no samples are placed after the objective, and even when I completely remove the tubelens and the objective.
    Thank you and regards
    michele
    Report Abuse
    • Reply
  • Pascal DLP
    on Mar 15 2012 13:10 PM
    Expert7510 points
    Michele,
    Thank you for the response and description of your system. I'm afraid that I can't tell from this level of detail how to address your question. It is probably necessary to see a diagram or optical layout with distances, stops, shielding, etc. to evaluate your system. There is some diffractive scattering from a DMD, but the details depend on many factors, primarily optical path - both illumination side and collection side.
    I can make it possible for you to establish a private link with me so that you may feel more free to give details. I'm sending you a Friend request, which will allow us to have a private conversation.
    Pascal
    Pascal
    Report Abuse
    • Reply
  • MBAE
    Posted by MBAE
    on Jun 05 2012 16:29 PM
    Prodigy105 points
    Dear Pascal,
    I am trying to build the same system that Michele built, DMD based confocal microscope for biological application too, but I am having troubles getting the diffraction pattern through the tube lens. I used a pair of lenses in order to shrink the image and to fit it to the back of the objective but it did not work. Can you please send me a Friend request ? I would like to chat with you about it.
    Best
    Martha
    Report Abuse
    • Reply
  • Pascal DLP
    on Jun 06 2012 09:28 AM
    Expert7510 points
    Martha,
    I have sent you a friend request.
    Pascal
    Pascal
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
