• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » New DLP Applications & Technology Forum » mirror reflectivity at 1550nm?
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
This question is not answered
Ben Cox
Posted by Ben Cox
on Apr 11 2012 06:12 AM
Prodigy10 points
What is the reflectivity of the mirrors on the DMD DLP5500 at a wavelength of 1550 nm?
Ben
DMD Optics DMD spatial light modulation DLP5500 reflectivity
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Justin Lemon
    Posted by Justin Lemon
    on Apr 12 2012 16:43 PM
    Intellectual285 points
    Hi Ben,
    Thanks for posting this question.  I just looked at the Datasheet titled, "DLP 0.55 XGA Series 450 DMD (Rev. B)," and it has some great information in regards to the DLP5500 (window transmission, and micromirror reflectivity, etc.).  According to the datasheet, The DLP5500 is designed for Visible light ranging from 420nm-700nm.  It also says the Single Pass Window Transmission (Efficiency) is ~97% and the micromirror reflectivity is around 88%.
    So when I reference the Single Pass DMD Window Transmission chart, it shows that around the 450nm mark (For VIS wavelength), it starts approaching to reach towards that 97% efficiency mark.  It continues to have that same efficiency of around 95-97% until it starts to hit the 700-750nm range.  So from that range of ~450nm to 700nm, the micromirror reflectivity stays around 85-88%.
    If you're using a VIS wavelength of 1550nm (we do not recommend you go over the suggested maximum in regards to wavelength.  A wavelenfth of 1550nm is twice as much than the recommended wavelength max of 750nm.  This could result in stuck pixels on the DMD over time and could eventually cause the DMD to slowly lose performance), the Window Transmission chart shows you are at about 70-75% efficient, so a decrease of about 20% from the recommended range (420nm-700nm).  If your micromirror reflectivity during the 95-97% efficiency range is around 88%, I would conclude that the it would drop by at least 25% once it hits that 1550nm range that you're using.  So I would estimate the micromirror reflectivity at 1550nm would be around 60% or so, max.
    It's hard to say exactly what the micromirror reflectivity would be at this range becuase it is twice the recommended amount and we would not suggest this.  But based on the datasheet and the Single Pass DMD Window Transmission charts, this is what I conclude.
    Here is the Extranet link to the datasheet I referenced.  I believe you will find it very helpful.
    http://www.ti.com/lit/gpn/dlp5500
    I hope this information helps Ben.  Good luck!
    Justin Lemon
    Report Abuse
    • Reply
  • Fizix
    Posted by Fizix
    on Apr 13 2012 16:46 PM
    Expert5210 points
    Hello Ben,
    Welcome to the DLP section of the TI-E2E community.  The window transmission chart that Justin is referring to can be found here: http://focus.ti.com/pdfs/dlpdmd/Type_A_window_transmission_Discovery_Website.pdf.  This chart is for a different DMD type, but the windows have the same coating and the  wndow glass has the same effective optical properties.
    The mirror reflectivity follows roughly the reflectivity of bulk aluminum, although other factors make the actual reflectivity slight lower.  A chart of Al reflectivity can be found at: http://en.wikipedia.org/wiki/File:Image-Metal-reflectance.png
    As you can see from the chart, after a brief dip at 730 nm the mirror reflectivity itsleft at 1000 - 5000 nm is quite good.  However from the window transmission chart (first link) you can see that the window transmission drops to about 75% at 1550 nm - this is for a single pass.  The result is a total loss of about 45% loss for the cumulative inbound pass plus outbound pass through the glass.  The chart shows an IR coated window, but this window is not available for S450 package DMD's.
    Justin is correct that TI does not recommend operating a DMD outside of parameters provided in the data sheet, which is 10 mW/cm2 for wavelengths greater than 700nm.  However, stuck pixels are not really expected in the IR range.
    Fizix
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
