• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » New DLP Applications & Technology Forum » NIR video-projection using DLP technology
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
  • Rasmus Larsen
    Posted by Rasmus Larsen
    on Feb 08 2009 08:04 AM
    Prodigy10 points
    We are interested using using  structured (lines or other patterns or combinations thereof) light pattern in multi-camera setups for surface reconstruction and tracking. In particular we would like to experiment with light in the NIR range. We would be interested in using a few (or even several) wavelength bands.
    Does the DLP® Pico™ Projector allow for substituting the red, blue and green LEDs with NIR LEDs?
    Can you point me to other solutions in finding a versatile NIR video projector
    Rasmus Larsen, Technical University of Denmark
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Fizix
    Posted by Fizix
    on Feb 09 2009 14:25 PM
    Expert5310 points
    Rasmus,
    Let me welcome you to the forums!  It is great to have you .
    I hope that the forum will be of help with your questions.
    We are looking to see how practical it would be and whether the lens coatings will permit it.  I will try to get back to you soon.
    Report Abuse
    • Reply
  • NumberSix
    Posted by NumberSix
    on Feb 24 2009 18:15 PM
    Prodigy30 points
    I can't say specifically about the Pico kit, but I would be cautious.
    Most optics come with coatings that significantly attenuate IR, even NIR, unless they have been specifically designed for IR operation.  That said, the DMD's coating does pass NIR at 90% range of efficiency, as long as you aren't going out too much beyond 850nm or so.  If you can live with very low throughput, you might be able to make do.
    Another issue is that RGB optics (including the Pico) will not correct for IR wavelengths.  Depending on the specifics of the prescription, this could lead to significant loss of projected MTF, astigmatism, etc. -- all of which tend to ruin structured lighting performance.
    I wish there were a more positive answer, but my suggestion would be to test your application in visible light.  If it works for your needs, our DMDs will do just fine in NIR and a custom NIR-only optical design would be very feasible (for a company that has done DLP optics before) and could certainly achieve the same performance as an RGB design.
    Report Abuse
    • Reply
  • mikeselectricstuff
    Posted by mikeselectricstuff
    on Feb 25 2009 08:41 AM
    Intellectual260 points
    for the Pico kit, I think you'd have to bypass the LED colour-combining optics completely, as these appear to be rather narrowband, and so may not let nay NIR through at all - I got almost no visible transmission from a blu-ray laser through the blue filter, but might be worth a try blasting a load of NIR through the red LED port before tearing further into the optical block.
    Report Abuse
    • Reply
  • NumberSix
    Posted by NumberSix
    on Feb 25 2009 10:11 AM
    Prodigy30 points
    Right, the LEDs are blasting through color dichroic mirrors to combine them.  Since all you'd need for NIR is a single "color", you'd just remove all the color LEDs and put the IR LED in the nearest position, replacing the dichroic with a simple mirror.  In theory anyway.
    Report Abuse
    • Reply
  • Madadayo
    Posted by Madadayo
    on Feb 25 2009 19:31 PM
    Prodigy95 points
    Another possibility is to replace the dichroics with narrowband filters that pass different small bandwidths of NIR spectrum. Then replace the RGB LED's with NIR LED's that match these bandwidths, if there is such a thing, so that the full combined bandwidth of all 3 LED's gets to the DMD.
    Of course there is still the problem of how efficient the optics would be at NIR since they were optimized for focus and performance at visible wavelengths. Not to mention the bandpass of the optical materials themselves, which includes acrylic optics.
    Mike Davis
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
