Hi sir,
I had same problem as following thread e2e.ti.com/.../597582.
Power is on when switch the mechanical power switch, but projector is not on when I press the push button. There is no signal from proj_on when I measure the test point. Push button should be fine. Seems like MSP430 did not send signal on proj_on. Please advise how the problem be solved. thank you.
Langston
