Other Parts Discussed in Thread: DLP3310, DLP4710, DLP3010, , DLPC150
Hi TI
I am investigating whether there is a DMD with a large tilt angle +/-17 degrees, which can run in pattern sequence mode (1-to-1 Input Mapping to Micromirrors) and support 8-bit patterns.
Is it correctly understood that none of the DLP3010, DLP3310, and DLP4710 can run in pattern sequence mode, because none of the corresponding controllers support pattern sequence mode?
Also, the DLP2010/DLPC150 can run in pattern sequence mode, but only has support for 1-bit patterns?
Claus
