TIDA-00782: GERBER files needed or at least the design files which can be opened
Part Number: TIDA-00782
I tried to open the design files for the TIDA-00782 (tidrhv2.zip) and I tried everything but there is simply no CAD tool that recognizes these files.
Could you please provide the valid files and/or GERBERs?
Thanks in advance.
Bogdan
  • Hello Bogdan,
    Sorry for the difficulty. Did you try using PADS Layout Viewer? I just confirmed I could open the files using that tool on my end.
    Kyle
  • Hi Kyle,
    Thanks for the effort. You are right, I managed to open it using PADS Layout Viewer. However, this did not solve my problem since I can't do anything with this tool other than just view the design. I figured that the idea of offering these files was to be able to make the development board ourselves but I guess I was wrong.
    Bogdan
  • Hello Bogdan,
    What are you trying to do on your end? If you are making your own custom front end usually you would want to start with the schematic and then you would be required to do your own layout. Our layout should hopefully provide you a reference of something that works. If I'm misunderstanding your desired use of the layout please let me know and I will see if we can help.
    Kyle
