• Resolved
DLP3010: DLP3010 DMD remove
Part Number: DLP3010
I have bought DLP 3010 EVM module. I need to disassemble DMD from the light engine in order to use it separably from the light engine optics. The DMD heat sink and the flex cable are glued, but does any body know if the DMD and TIR prism are glued or have a physical connection.
Thank you in advance for your answers.
  • Hi Daniel,
    Welcome to DLP forum and thank you for your interest in DLP technology.
    There should not be any glue between DMD and prism. They should be mechanically held together by the engine housing. The Flex cable, heat sink and mounting is glued together to prevent any loose connection due to handling and transportation.
    regards,
    Vivek
