• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C5000 Ultra Low Power DSP » C5000 Ultra Low Power DSP Forum » ezdspC5535 used as audio effects processor
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Top 6 Wiki Links
  • C5000 Main Wiki
  • C5000 Software
  • C5515 Boot-Image Programmer
  • CSL (including CSL 3.00)
  • C5000 Connected Audio Framework
  • Porting C5000 Teaching ROM to C5535 eZdsp
  • ezdspC5535 used as audio effects processor
    This question is answered
    michael swanson
    Posted by michael swanson
    on Jan 31 2012 16:01 PM
    Prodigy100 points
    My partner and I are trying to use the ezdspC5535 as an audio effects processor intended for use by musical instruments for our senior project in electrical engineering at the University of Vermont.  We want to use this device for real-time playback of effected audio signals.  We would like to input the signals through the stereo input jack J3 and output them through the stereo output jack J4.  Upon reviewing the documentation associated with the connected audio framework we have come to understand that for real-time playback of audio the signals go through the micro USB port J1.  We want to know if it is possible to change the path from which we input signals for real-time playback.  Ultimately we want to insert our own filter algorithms into the playback path, but we would like our input to be directly from the instrument itself via an 1/8th inch jack not the USB.
    Any advice or help would be greatly appreciated.
    Mike & Mike
    DSPLib USB sample code eZdsp CCS4 DSP Code Composer Studio C5535 eZdsp C5535 playback
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Mark Mckeown
      Posted by Mark Mckeown
      on Jan 31 2012 18:49 PM
      Verified Answer
      Verified by michael swanson
      Genius10200 points
      Hi Mike and Mike,
      Cool project - C5000 DSPs are well suited for real-time audio processing.
      Check out the examples in the C5000 University Teaching ROM - 20 labs that use the audio input and output jacks for filtering, audio effects, etc. I have used these labs with the pickups of an electric guitar as the audio source - it worked well.
      These labs are written for the C5505 and C5515 eZdsps, but are easily ported to the C5535 eZdsp. I have been meaning to write the wiki article on the porting - essentially replace I2S0 with I2S2 in all instances - I2S2 is connected to the AIC3204 codec on the C5535 eZdsp whereas I2S0 was connected to the codec on C5505 and C5515 eZdsps.
      For your project, the connected audio framework might not be the best starting point unless you require USB streaming playback or record.
      Let us know how we can help.
      Mark
      Please click the Verify Answer button on this post if it answers your question.
      Also see our C5000 Wiki
      Report Abuse
      • Reply
    • michael swanson
      on Feb 01 2012 21:51 PM
      Prodigy100 points
      Mark,
      Thanks for the quick response, your help is appreciated.  We attempted to begin the first lab in Chapter 1.  We changed I2S0 to I2S2 in the files, and got the code to build without any errors or warnings.  When attempting to debug the program we ran into issues.  We think the code is set up to work with the C5505 processor and we are unsure how to get it to debug with our processor.  We would be grateful for any help.
      Mike & Mike
      Report Abuse
      • Reply
    • Mark Mckeown
      on Feb 02 2012 14:32 PM
      Verified Answer
      Genius10200 points
      Mike and Mike,
      Try replacing the original Teaching ROM files with these attached modified files.
      I bet your problem was not making this change to the EBSR register (pin mux) to bring out I2S2...
      SYS_EXBUSSEL = 0x1000;  // Configure PPMODE 1 = I2S2
      3542.C5000 Teaching ROM Port to C5535 eZdsp.zip
      This is going on the wiki for sure.
      Hope this helps,
      Mark
      Teaching ROM
      Report Abuse
      • Reply
    • Mark Mckeown
      on Feb 02 2012 18:19 PM
      Verified Answer
      Genius10200 points
      Mike and Mike,
      I have created this Porting C5000 Teaching ROM to C5535 eZdsp wiki page:
      http://processors.wiki.ti.com/index.php/Porting_C5000_Teaching_ROM_to_C5535_eZdsp
      Successfully verified this port on all 20 Teaching ROM labs!
      Mark
      C5000 Teaching ROM C5535 eZdsp
      Report Abuse
      • Reply
    • michael swanson
      on Feb 07 2012 16:13 PM
      Prodigy100 points
      Hey Mark,
      We are having issues still getting the first program to run.  We followed the steps included in the wiki, but still can't hear any audio being output.  We have observed that the demo code is still loaded onto our device, and can in fact still play audio from our PC through the micro-USB.  Would this be an issue if this code is still on our device?  Is there any specific way we should be loading code on our device in order to clear out old code?  We appreciate your help so far, and we think we are very close to figuring this out.
      Mike & Mike
      Report Abuse
      • Reply
    • Mark Mckeown
      on Feb 07 2012 17:42 PM
      Verified Answer
      Genius10200 points
      Hi Mike and Mike,
      Try to import this existing CCS4 project.
      4174.Chapter 1 - C5535 eZdsp.zip
      michael swanson
      Once you connect to the eZdsp from within code composer, that demo program should stop running - the OLED will keep its display until power cycled or written to.
      Make sure you are connecting to the J2 USB port when you connect to the eZdsp through CCS.
      Isnt the demo code stored on the microSD card? Why not just remove the microSD card to stop the demo code from running?
      After connecting to the eZdsp, and after building the CCS4 project, use the load program feature to load the .out file into the DSP internal memory.
      Then using the debugger, run the program by clicking on the Green Run arrow button.
      Let me know where you are getting stuck.
      Hope this helps,
      Mark
      Report Abuse
      • Reply
    • michael swanson
      on Feb 08 2012 16:21 PM
      Prodigy100 points
      Mark,
      Thank you very much!  We weren't familiar with devices that required manual loading, and sure enough loading the .out file allowed us to play audio through our device.  We appreciate all your help.
      Mike and Mike
      Report Abuse
      • Reply
    • michael swanson
      on Feb 09 2012 16:09 PM
      Prodigy100 points
      Mark,
      Now that we have this process complete we have run into another small road block.  It appears that in order for us to have a program run while the ezDSP is not connected to the computer via J2 we need to load a boot-image of the program onto the device.  We found an article on this, but we had trouble understanding the full process.  Could you give us some advice for how to perform this process correctly?  Thanks again for all your help, you have been an invaluable resource to us.
      -Mike & Mike
      Report Abuse
      • Reply
    • Mark Mckeown
      on Feb 09 2012 16:52 PM
      Genius10200 points
      Hi Mike and Mike,
      Not a problem.
      Here's the flow of things:
      1. Build project in CCS4
      2. Copy the .out file created during build to some folder without any white spaces in the path (.out file is located in Debug folder of project dir)
      3. Copy hex55.exe to this directory (located in <CCSv4 Path>\ccsv4\tools\compiler\c5500\bin\hex55.exe)
      4. In same directory, create and edit hex55.bat file that calls hex55 (copy and modify the one attached with your .out file name)
        - Only 1 line in .bat file: "hex55 -boot -v5505 -serial8 -b -i Chapter1-5535.out -o bootimg_Chapter1-5535.bin"
      5. Run hex55.bat from CMD line or double click on .bat file
      6. bootimg_Chapter1-5535.bin will be created after running
      7. SD Card Boot:
        Rename bootimg_Chapter1-5535.bin to bootimg.bin
        Copy bootimg.bin to microSD card using Windows & SD Card reader (only one bootimg.bin file will boot)
        Insert microSD card into C5535 eZdsp card slot
        Power board, bootloader runs, finds bootimg.bin file, copies it to internal memory, and begins execution
      8. SPI Flash Boot:
        Load progammer.out for C5535 eZdsp with CCS4 (download from Spectrum Digital Page)
        Run program
        Paste full path + file name of .bin file into console (cant have white spaces), Press Enter
        Wait for programmer to complete
        Power board, bootloader runs, finds valid boot signature in SPI flash, copies .bin file to internal memory, and begins execution
      SPI Flash has precedence over SD Boot if both have valid images - SPI Flash can be disconnected (boot avoided) by switching DIP SW3 Pin 4 to OFF
      See http://www.ti.com/lit/an/sprabl7a/sprabl7a.pdf:
      "Each device has a fixed order in which it checks for a valid boot image on each supported boot device. The device order is 16-bit SPI EEPROM, 24-bit SPI serial flash, I2C EEPROM, and SD/SDHC/eMMC/moviNAND"
      Hex55 Reference: See http://www.ti.com/lit/ug/spru280i/spru280i.pdf - Chapter 13 - Hex Conversion Utility Description
      Also try this attached bootimg of Teaching ROM Chapter 1 ported to C5535 eZdsp that I created with this procedure:
      • Rename it to "bootimg.bin", copy to SD card, and boot
      • Play music from PC or phone plugged into STEREO IN, Listen to output with headphones plugged into STEREO OUT
      1731.bootimg_Chapter1-5535.bin
      Hope this helps,
      Mark
      bootloader C5535 eZdsp Teaching ROM
      Report Abuse
      • Reply
    • Krzysztof Koziol
      Posted by Krzysztof Koziol
      on Mar 08 2012 06:55 AM
      Prodigy25 points
      Dear Mark,
      I would like to check the Teaching ROM examples, but it seems the link http://www.ti.com/ww/eu/university/cd-rom/c5000.zip from TI University Program is not active. The other ROMs (From MATLAB and SIMULINK to Real Time... and C6000 Teaching ROM) can be downloaded.
      Is it possible to get still the C5000 Teaching ROM content?
      BTW, I am starting with the eZDSP USB stick for C5515 and would like to make a SPL meter using A-weighting filtering and True-RMS measurement.
      Did you see any similar project examples?
      Thanks for help!
      Cheers,
      Krzysztof
      Report Abuse
      • Reply
    • Mark Mckeown
      on Mar 08 2012 13:15 PM
      Genius10200 points
      Hi Krzysztof,
      Here is the correct link to the EU University Teaching ROMs: http://www.ti.com/ww/eu/university/roms.html
      The Teaching ROM has labs for FIR, IIR, multirate filters, FFTs, and MATLAB examples but it does not have coefficients or the algorithms for A-weighting or efficient RMS.
      Neat project, for A-weighting do you plan to use IIR, biquads, or maybe FFT?
      Also the DSPLIB has sum of squares of a vector (power) and square root of a vector functions.
      Hope this helps,
      Mark
      Report Abuse
      • Reply
    • Krzysztof Koziol
      on Mar 09 2012 14:31 PM
      Prodigy25 points
      Hello Mark,
      thanks for your answer. I have downloaded the exaples. Looks very helpful, just starting play with.
      I don't know yet what type of filtering I will use for A-weighting curve. I will try first with a FIR. If there will be not enough of memory/time will try IIR. I have to note, I'm just start the adventure with the DSP, so I'm greenhorn in this :-) Any help is welcome.
      Greetings,
      Krzysztof
      Report Abuse
      • Reply
    • michael swanson
      on Mar 29 2012 18:09 PM
      Prodigy100 points
      Mark,
      We have been making great progress with our audio effects processor project thanks to all your help.  I was curious if you could help us out with our most recent issue.  We are using a resistive touch pad to alter filter parameters on our DSP.  We have been working with this touch pad controller for the past couple of weeks and we would like to communicate data from our touch pad controller to the C5535 using i2c communication.  In order for us to verify whether or not our touch pad controller is working correctly, we would like to write data from it to our DSP using i2c and then read the data to confirm that it is in fact working.  Are there any good pieces of demo code that spell out how to do this i2c writing and reading?  Any help would be appreciated.
      Thanks again,
      Mike & Mike
      I2C C5535 eZdsp
      Report Abuse
      • Reply
    • Mark Mckeown
      on Apr 03 2012 11:28 AM
      Genius10200 points
      Hi Mike & Mike,
      I would reuse the usbstk5505_i2c.c and usbstk5505_i2c.h files included with the teaching ROM materials. USBSTK5505_I2C_read() and USBSTK5505_I2C_write() may need to be modified based on the data format of your I2C device.
      Do you have a datasheet to check the I2C data format?
      The AIC3204 codec and the OLED (Chapter 20) are configured with I2C commands, so you can study the code for these devices, and modify it to work with your device.
      For I2C peripheral details, see Chapter 9 of the C5535 Technical Reference Manual.
      Hope this helps,
      Mark
      Report Abuse
      • Reply
    • michael swanson
      on Apr 14 2012 17:57 PM
      Prodigy100 points
      Hi Mark,
      We have been able to use the C5535 to communicate with our resistive touchpad using i2c communication.  We are using the functions USBSTK5505_I2C_read() and USBSTK5505_I2C_write().  One issue that has come up is that using the USBSTK5505_I2C_read() to read coordinate data from our resistive touchpad has somehow been interfering with the use of the audio codec.  Included below is our code.  We are just simply trying to use the coordinate data from the resistive touchpad to attenuate the output signals, kind of like a volume control pad.  Upon commenting out both the read and the write we were able to hear our sound signals pass through the system fine.  After reintroducing the write commands we are still able to hear our sound signals pass through the system.  Upon reintroducing the read command our sound signal does not pass through the system well.  We essentially get a extremely incoherent noisy signal.  Is there a certain way we should be using this read function in order to not interrupt the use of the audio codec?
      Thank you,
      Mike & Mike
      void main( void )
          /* Initialize BSL */
          USBSTK5515_init( );
          /* Initialize PLL */
          pll_frequency_setup(60);
          /* Initialise hardware interface and I2C for code */
          aic3204_hardware_init();
          /* Initialise the AIC3204 codec */
          aic3204_init();
          /* Turn off the 4 coloured LEDs */
          USBSTK5515_ULED_init();
          /* Initialise the OLED LCD display */
          oled_init();
          SAR_init();
          oled_display_message("                 ", "                   ");
          printf("\n\nRunning Project Echo and Reverberation\n");
          printf( "<-> Audio Loopback from Microphone In --> to Headphones/Lineout\n\n" );
          /* Setup sampling frequency and 30dB gain for microphone */
          set_sampling_frequency_and_gain(SAMPLES_PER_SECOND, GAIN_IN_dB);
          oled_display_message("Application 3      ", "Echo and Reverb    ");
          /* New. Add descriptive text */
          /* New. Default to XF LED off */
          asm(" bclr XF");
          /* i2c comm with mtouch device */
         enableTouch[0] = 0x9A;
         enableTouch[1] = 0x00;
         enableTouch[2] = 0x55;
         enableTouch[3] = 0x01;
         enableTouch[4] = 0x12;
        passFail2 = mTouch_multiSend( enableTouch, 5 );
        printf("Passfail2 %d\n", passFail2);
        xTemp = 0;
           while(1)
          passFail = USBSTK5505_I2C_read( 0x4D, cmd, 5);
          // initialize at zero parameters
            if(cmd[0] != 0x81 && cmd[0] != 0){
                cmd[1] = 0;
                cmd[2] = 0;
                cmd[3] = 0;
                cmd[4] = 0;
      //      printf("Address 1 %x\n", cmd[0]);
      //      printf("Address 2 %x\n", cmd[1]);
      //      printf("Address 3 %x\n", cmd[2]);
      //      printf("Address 4 %x\n", cmd[3]);
      //      printf("Address 5 %x\n", cmd[4]);
      //      printf("Passfail %d\n", passFail);
            x1 = cmd[4];
            x2 = cmd[3];
            x3 = (x1 << 7) + x2;
            printf("%x\n", x3);
           aic3204_codec_read(&left_input, &right_input); // Configured for one interrupt per two channels.
           left_output = left_input;      // Straight trough. No processing.
           right_output = right_input;
           aic3204_codec_write(left_output, right_output);
            Step = pushbuttons_read(1);
            //if ( Step == 1 )
               //if ( Step != LastStep )
               //  oled_display_message("STEP1 No Processing", "      Set Levels   ");
               //  LastStep = Step;
               /*if( (x3 - xTemp) < 4000 && (x3 - xTemp) > 3000){
               left_output = left_input/100;      // Straight trough. No processing.
               right_output = right_input/100;
               else if( (x3 - xTemp) < 2000 && (x3 - xTemp) > 1000){
               left_output = left_input/50;      // Straight trough. No processing.
               right_output = right_input/50;
               else if( (x3 - xTemp) < 1000 && (x3 - xTemp) > 0){
               left_output = left_input/25;      // Straight trough. No processing.
               right_output = right_input/25;
                xTemp = x3;
           bargraph_6dB(left_output, right_output);
         /* Disable I2S and put codec into reset */
          aic3204_disable();
          printf( "\n***Program has Terminated***\n" );
          oled_display_message("PROGRAM HAS        ", "TERMINATED        ");
          SW_BREAKPOINT;
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
