• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C5000 Ultra Low Power DSP » C5000 Ultra Low Power DSP Forum » EMIF and DSP/BIOS
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Top 6 Wiki Links
  • C5000 Main Wiki
  • C5000 Software
  • C5515 Boot-Image Programmer
  • CSL (including CSL 3.00)
  • C5000 Connected Audio Framework
  • Porting C5000 Teaching ROM to C5535 eZdsp
  • EMIF and DSP/BIOS
    EMIF and DSP/BIOS
    This question is not answered
    Matthieu Remacle
    Posted by Matthieu Remacle
    on May 10 2012 14:39 PM
    Prodigy100 points
    Hi.
    I’m trying to use the EMIF with a TMS320C5502 and DSP/BIOS. On the EMIF is connected a 4Mb (256k*16) ASRAM on CE0, the other CE are empty. It’s important to note that there is a FPGA in between, which is not yet programmed (still waiting for the programmer…) so the signal don’t actually go to the memory. However, I guess I should see some signal trying to go to the ASRAM since the EMIF should send the data and not waiting anything in return…
    So here is what I did:
    -          In the DSP/BIOS configuration, I added under the MEM module a new object (ASRAM), configured like this:
    Base: 0x010000
    Len: 0x3f0000
    Create a heap in this memory: True
    Heap size: 0x3f80
    User definied identifier: True, EMIF0
    Space: Code/data
    -          I configured the EMIF register like this:
    void EMIF_Init(void)
            EMIF_Config cEMIF = {
                EMIF_GBLCTL1_RMK(
                        EMIF_GBLCTL1_NOHOLD_HOLD_ENABLED,
                        EMIF_GBLCTL1_EK1EN_ENABLED,
                        EMIF_GBLCTL1_EK1HZ_HIGHZ),
                EMIF_GBLCTL2_RMK(
                        EMIF_GBLCTL2_EK2RATE_1XCLK,
                        EMIF_GBLCTL2_EK2HZ_HIGHZ,
                        EMIF_GBLCTL2_EK2EN_DISABLED),
                EMIF_CE1CTL1_DEFAULT,
                EMIF_CE1CTL2_DEFAULT,
                EMIF_CE0CTL1_RMK(
                        EMIF_CE0CTL1_TA_OF(3),
                        EMIF_CE0CTL1_READ_STROBE_OF(12),
                        EMIF_CE0CTL1_MTYPE_16BIT_ASYNC,
                        EMIF_CE0CTL1_WRITE_HOLD_MSB_LOW,
                        EMIF_CE0CTL1_READ_HOLD_OF(7)),
                EMIF_CE0CTL2_RMK(
                        EMIF_CE0CTL2_WRITE_SETUP_OF(2),
                        EMIF_CE0CTL2_WRITE_STROBE_OF(15),
                        EMIF_CE0CTL2_WRITE_HOLD_OF(3),
                        EMIF_CE0CTL2_READ_SETUP_OF(2)),
                EMIF_CE2CTL1_DEFAULT,
                EMIF_CE2CTL2_DEFAULT,
                EMIF_CE3CTL1_DEFAULT,
                EMIF_CE3CTL2_DEFAULT,
                EMIF_SDCTL1_DEFAULT,
                EMIF_SDCTL2_DEFAULT,
                EMIF_SDRFR1_DEFAULT,
                EMIF_SDRFR2_DEFAULT,
                EMIF_SDEXT1_DEFAULT,
                EMIF_SDEXT2_DEFAULT,
                EMIF_CE1SEC1_DEFAULT,
                EMIF_CE0SEC1_DEFAULT,
                EMIF_CE2SEC1_DEFAULT,
                EMIF_CE3SEC1_DEFAULT,
                EMIF_CESCR_RMK(0x0002)
            EMIF_config(&cEMIF);
    -          Finally, I made this code:
    void testMemory(void)
    	int* test_block;
    	test_block = (int*)MEM_alloc(ASRAM, 0x800, 0);
    	int i;
    	while(TRUE)
    		for(i = 0; i<63; i++)
    			*(test_block + 4) = i;
    Finaly, in my .h, I added this line so the compiler don't complain about the ASRAM in the MEM_alloc (cause I saw on the net there was a bug with the Tconf generator...)
    extern const Int ASRAM;
    In code composer, when I stop, the pointer test_block has the good value (0x00010000),  is located in the DARAM (0x0015C4@DATA), but the value of *(test_block) is -1. And when I look at the scope, I don’t have anything between the FPGA and the  DSP…
    So, where did I screw up?
    Thanks a lot!
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • David Friedland
      Posted by David Friedland
      on May 10 2012 17:01 PM
      Genius13420 points
      Matthieu,
      As far as your BIOS configuration goes, what you did seems OK.  At this point, your question probably is beyond the expertise of people on the BIOS forum, so I am moving this thread over to the C5x device forum in hopes that you will get a faster response there.
      Dave
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
