Hi Sirs,
Is there any someone to know how to use C5535's SPI to control AIC32xx Codec?
Can share example code to me. Thanks a lot
Eric
Hi Sirs,
Eric
Hello Eric,
For information on C5535 SPI controls refer to the technical reference manual in the Below link.
You can also refer to SPI CSL examples, this can be downloaded and installed from the below link.
CSL C5000 : Pl Note the example is a generic SPI example which illustrates configuration/read & write to EEPROM.
Also question to you is, why don't you use I2S to interface with Codec ?
For more information on interfacing Codec with C5535 can be found in below link ( Refer to TRM/Schematic) .
Hope the above information helps you .
Vasanth
