Hi all,
The customer uses TMS320C5505 DSP on one of their boards. There is a shortcut between Vdd and Vss on the board.
When they unmounted the IC, they detected that there is a shortcut between the balls G7 (Vss) and F7 (DVDDIO).
By the way, it is written on sprs660f.pdf on table-2.21 that DVDEMIF signals can be connected to ground if EMIF isn't used on the design. They suspect if that can cause a problem. Because they connected DVDDEMIF signal to ground.
Could you please advise?
Mete
