Hi Sir,
If the SD card format was error or SD card FAT was damaged , I can use format successful on the PC , but I can't format successful via ATA_format in C5515.
Could you give any suggestion?
Hi Sir,
Hi Sir,
I used ccs_v5.0_examples code(CSL_MMCSD_SdCardFSExtExample) , the message is as below for your reference.
If the SD card can be fixed via ATA_format command in C5515 , it would be good for our application.
A good SD card:
MMCSD-ATAFS TESTS!
MMCSD-ATAFS POLL MODE TEST!
SD Card detected
SD card is High Capacity Card
Memory Access will use Block Addressing
SD card initialization Successful
ATA File System Initialization successful
File Creation/Open on SD card is Successful
Writing Data to the file on SD card successful
Reading Data from the file on SD card successful
MMCSD Read and Write Buffers Match
MMCSD-ATAFS POLL MODE TEST PASSED!!
MMCSD-ATAFS DMA MODE TEST!
SD Card detected
MMCSD-ATAFS DMA MODE TEST PASSED!!
MMCSD-ATAFS TESTS PASSED!!
A bad SD card:
MMCSD-ATAFS TESTS!
SD Card detected
ATA_readLittleEndian Failed
MMCSD-ATAFS POLL MODE TEST FAILED!!
SD Card detected
MMCSD-ATAFS DMA MODE TEST FAILED!!
MMCSD-ATAFS TESTS FAILED!!
