If I use ATA_fopen or ATA_fcheck to open/search SD card data when the SD card has 500 over data.
The SD card performance was very slow.
Could you provide some suggestion to improve SD card performance?
Could you provide an example for fast searching data on SD card?
AtaError ATA_fopen(AtaFile *pAtaFile, char *name/*, char *ext*/)
char nameUp[FileName_Length] = {0};
short counter;
AtaError ata_error;
Uint16 g_i16ErrorCNT = 0;
ata_error = ATA_ERROR_MEDIA_REMOVED;
for (counter=0; counter<strlen(name); counter++)
nameUp[counter] = toupper(name[counter]);
nameUp[counter] = 0;
ATA_findFirst(pAtaFile);
// find the file, if it exists
do
g_i16ErrorCNT++;
// get the file name for this entry
ata_error = ATA_getLongName(pAtaFile, &ATA_FileName[0], 0, strlen(name)/*+strlen(ext)*/+1);
// file name is the same?
if ((strncmp(ATA_FileName,name,strlen(name)) != 0)&&(strncmp(ATA_FileName,nameUp,strlen(nameUp)) != 0))
// if the file name is not the same, get the next entry
ata_error = ATA_findNext(pAtaFile);
// have we get the empty entry?
if(ata_error==ATA_ERROR_FILE_NOT_FOUND)
break;
if(ata_error==ATA_ERROR_NONE && g_i16ErrorCNT>REC_Files_Number)
return ATA_ERROR_DISK_FULL;
else
// we have a match
return ata_error;
while (1);
// if the file does not exist, then create it using the empty entry and return the file descriptor
if (ata_error==ATA_ERROR_FILE_NOT_FOUND)
// set the file name and extension name
ata_error = ATA_setLongFileName(pAtaFile, (char*)name);
/* Create a file, returns 0 for successful creation*/
ata_error |= ATA_createLong(pAtaFile, (char*)name);
return ata_error;
AtaError ATA_fcheck(AtaFile *pAtaFile, char *name,char FileName[FileName_Length],Uint8 islogo)
char nameUp[10];
short counter;
AtaError ata_error = ATA_ERROR_NONE;
do
ata_error = ATA_getLongName(pAtaFile, &FileName[0], 0, FileName_Length); // Log.txt
if ((strncmp(FileName,name,3) != 0)&&(strncmp(FileName,nameUp,3) != 0))
break;
else
// we have a match
return ata_error;
while (1);
//ata_error = ATA_getLongName(pAtaFile, &FileName[0], 0, strlen(name)/*+strlen(ext)*/+1);
return ata_error;
