We are Integrating T.38 FAX Relay feature for one of our ongoing developments which is based on TMS320C5510A DSP Microcontroller.
We require technical assistance for the clarifications we have.In this regard we are looking forward to get connected to the concerned team or person at TI.
Telephone /Fax machine is connected through a 2 wire telephone line to a subscriber line interface card (SLIC).
Analog codec trans receives analog signals through SLIC. Analog codec interfaces MCBSP0 of DSP with PCM signals. This data is then converted to different voice codecs and transmitted through MCBSP1.
Now we are trying to integrate T.38 FAX relay in DSP TMS320C5510A.
We have downloaded faxlib(faxlib_C55_2_1_0_1) for T.38 FAX relay, Can you suggest the steps required to integrate it with our system?
We need information on Clock and Frame synchronization for FAX Relay.
Could you please share any documents or schematics related to T.38 Fax relay integration.
A System block diagram has been given below for detailed information to this post.
