When running the example CSL_I2S_IdleLoop_Out, I get the following output
I2S Idle Loop Example This Example will continuously Pump a Sine Wave Signal to the Audio Output using the Codec Please connect the Headphone to the Audio Output (Headphone) Jack I2S Module Instance opened successfully I2S Module Configured successfully Pumping of a Sine Wave Signal to the Audio Output Started!!
This is what my board configuration looks like:
However, I do not hear anything coming from the output jack. Is this the correct setup?
