I have downloaded the TIDEP0066 software from ti.com and during compilation, i get the error that "TIesrDemoC55cfg.h" cannot be found. Can someone help to send me the file?
Thanks.
BR,
Dunman Teo
Thanks.
BR,
Dunman Teo
Dunman,
That is a strange error as the .h file you are referring to is created in the Debug folder at compile time. Did you ensure your environment, and BIOS version are as described in the document? Could you also try a "clean" and "build" in CCS?
Lali
Yes, I did. The only error flagged up is suggesting that the project was built for a target that is not currently supported. Currently it is set to "TMS320C55XX, TMS320C5515,EVM5515". Do I need to change this setting?
BR,
Dunman
Dunman,
The default .out for the demo is part of the original source code package under \tidcbz3\TIesr_src\TIesr_C55_demo\build\ccsv5\Debug\TIesrDemoC55.out
Did you do step 11 of section 5.2.3 of the design guide where you modify csl_general.h to the C5535 platform in the CSL?
Lali
/cfs-file/__key/communityserver-discussions-components-files/791/2553.2768.TIesrDemoC55.out
